clear listbox & auto-arrange line of table
Hi all
May I know how can I clear / empty the listbox which contain data? AND
How can I auto-arrange the column line of the table? because after data are adding into it, user need to manually adjust the width of the column in order to view the full length of data.
THANKS!!!!
(4,877 Views)
to clear a listbox, you have to create a property node (left click on terminal -> creat -> property node)
select "item names" change the item to write and connect a empty string array to it. then it's empty. (Do the same with ItemSymbols if you use them. Set value to 0)
AFAIK there is no way to autoarrange the column width.
Rainer
(4,872 Views)
It's a crude solution, but it may work for you.  Use a fixed width font, find the longest string, and use the string length to set the listbox width.  Note, I got some very odd behaivors with width = 0, so I coerced the low end to 20.
(4,855 Views)
Hint:
"Get Text Rect.vi" (on the picture palette) will return a cluster that you can use to determine the actual number of pixels required to display a string.
No guess work required.
Ben
(4,852 Views)
Neat!
Message Edited by jasonhill on 02-16-2006 09:04 AM
(4,847 Views)
