clear small amount of previous data on a graph & plot new data.
I have got a large array of data coming in from ADC which has to be plotted on a graph.
Whenever it exceeds the front panel size of the graph, I want the data to be plotted again beginning from the start.
It has to erase/clear the previous data on the graph when the front panel display size is exceeded.
I do not want to clear the entire data and plot the new data. It has to clear only small amount of data and plot the new data in its place.
Can you please help me in finding a solution?
(2,478 Views)
Sounds like you need a chart and not a graph. This will constantly update as you input data, you can set the history of the chart.
Rgs,
Lucither.
"Everything should be made as simple as possible but no simpler"
(2,473 Views)
Hi siddharth,
Why dont you extend maximum x scale range? This will work for chart, waveform graph and XY graph.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,456 Views)
