clear waveform chart history if dynamic 1D data is used
I am new to Labview and am using a Waveform Chart.  To clear this I need to supply an empty array.  I have done this with scalar inputs, but in this present case, the input to the chart is a bundle of 1-D array of dynamic data. I cannot figure out how to create a suitable empty array of type 1D array of dynamic data to initialize the plot (wire to the History).
It seems like there should be a better (easier) way of clearing the plot...
Thanks for any ideas.
(3,262 Views)
Accepted by topic author rockybooth
Hi rockybooth,
right click on the connector to the history property and select "create constant". You should get what you need.
Hope it helps.
Mike
(3,249 Views)
