clear xy graph
Hi All,
i would like to clear xy graph. For example by clearing chart, i create a property node 'history data' and connect with constant, thus will clear the graph. What about xy graph? there's no such things as 'history data'.
Thanks & Regards,
Isa
(4,856 Views)
Just create a property node "value" and connect with constant.
Hope it helps you.
Vincent
V-F
(4,854 Views)
Accepted by topic author Isabella
Hi Isa,
you can use the "value" property or you directly connect your "empty data" to the indicator.
Mike
(4,853 Views)
