click on list box indexes and display respective information during run time.
I have a list box on the front panel. Each list box index has some data that is stored in a cluster array. I am trying to make my front panel list box interactive, so that the user can click on an index to view the data, sort the list box or remove index(s).
My problem is that i cannot make all this work at runtime. A user will have to run the app every time they want to search, sort or view something and i'm sure they'll will fuss at me for doing that Smiley Sad I'm currently using LV 6.0 and do not have the event capturing capability. Is there a way of doing this with LV 6.0 ?
vik.
(2,387 Views)
Hi vik
Use a shift register to compare the current index with the previous index. If they are different, you can execute some code.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,374 Views)
