client limitations
Dear sir,
i am using datasocket connection to transfer the data between computers. Presently i am having one computer as a server and from that server  we are sending the data using datasocket write function. In the client side i am using datasocket read function i am reading the data. There are one server computer and 5 client computers. I have made one server exe and  one different exe for client computer. when i installed server exe on any computer its becomes as server and same for the client. Now i want to restrict this client limitations i.e. no. of clients.How can i do it? i want to restrict this client limitations programatically so that user can not change it.
thanking you
falgandha mohire
(3,604 Views)
If you are using a DataSocket connection, the standard way to control the number of clients is by using the DataSocket Server Manager.  To do this programmatically, you would probably have to use the lower-level TCP/IP VI's and it would require some extensive programming.  I would recommend that you looking into our LabVIEW DSC Module, which provides user-level security VI's that can be used to limit the number of clients, and provide additional security options as well.  Please view the link below for more information.  Thanks Falgandha!
Meghan M.
(3,568 Views)
