Hello Shea,
I need for the part Endurance a pause function.
I'm using this VI to control a endurance sequence for High Pressure Cleaners.
This means it runs for a time with control over the Liquid flow and Pressure.
If the Pressure is to high or to low / if the flow is to high or to low the endurance sequence should be paused. When i have checked the HPC on failure and somthing is broken (example: the high pressure hose) is replace that part, and press then pause on the screen and the system runs again. But when the HPC is broken the in reset the clock to 0 with the reset button.
i have also changed the vi with the clock in it. Placed in the VI: Flow and Pressure control.
I didn't try the breakpoint function yet, because i'm still le
arning with Labview. i'll try it later on today when i get the time for it.
Thanks, William Strijks
Service Engineer
Kinzo tooling - Holland
Running with Labview 6.1
Fieldpoint hardware
