clone a tpc 2006
I was wondering if anyone knows of an simple way to clone all of the software located on a TPC 2006 onto a second TPC 2006?
(2,622 Views)
I would recommend using a hard drive imaging utility such as Norton Ghost to image the CompactFlash card. You can then push that image onto another TPC. For this, you will need a CF-to-USB or a CF-to-SATA adapter that will allow you to connect the card to your development machine to create and push the image.
It is recommended that you create a 'golden' image of your system once all of the software is installed and use this image to duplicate installations on other TPC targets.
Tannerite
(2,596 Views)
