close a VI template
My VI works well, however when the .vit opens front panel, this doesn't close with the button "CLOSE" because the program has been stopped. It seems as the vi template executes and stops. I don't know how use the button "CLOSE" to close front panel while the pop up is running and, at the same time, appears severals pop up (each pop up for each number).
Vicen
WinXP / LV7.1
thanks
(2,955 Views)
sorry, this is the good file.
(2,954 Views)
Use the method run on the .vi reference inside the main vi
Use a event case inside the .vit that waits on the stop button, then close the reference and the fp
One tip: wire the value in the .vit straight into the case selecter and add for every range another string.
Ton
My LabVIEW Ideas
(2,950 Views)
Thanks, I've solved my .vit
I don't know where insert method "run VI". I have to replace "call by reference node"? I thought "Run VI" used with weakly type VI reference (at least in all example I see).
(2,940 Views)
