close reference
Anyone can help to see where i went wrong? I run this as a subVI in my other program and my MS word open in blank while processing need to manually close the MS word application. Thank you very much
Regards
Ander
Message 1 of 8
(3,653 Views)
Hi Ander,
use an invoke node to close your document and then an invoke node to quit the application.
Mike
Message 2 of 8
(3,630 Views)
Currently i using invoke to close and quit but dunno what went wrong
Message 3 of 8
(3,627 Views)
Hi Ander,
maybe there occures an error before the invoke nodes. Did you checked it?
Mike
Message 4 of 8
(3,618 Views)
I can run it with my main program but not standalone. By the way. can i initialise a graph to empty? It it because my program plot out the graph using LV default graph output icon but it never clear the graph after i re-run again. It clear only when i exit the program and start again. How do i program to clear graph?
Message 5 of 8
(3,610 Views)
Hi Ander,
i don't see the "Quit" method in your code, insert it to close word.
If you connect empty data to the graph indicator, then it shows  nothing.
Mike
Message 6 of 8
(3,604 Views)
It is in the other frame i created in frame 1 and frame 2. I close document and quit application. I do not know what went wrong. Can show me some light?
Message 7 of 8
(3,601 Views)
Hi Ander,
see the attached example please. It only shows the open and close process.
Mike
Message 8 of 8
(3,589 Views)
