closing references of reentrant vi
Hello fellow labviewers,
I am struggling to deal with a problem (or as I like to call it "opportunity").
I have a program which launches various reentrant VIs, typically around 7 or 8 of them. The problem arises when I want to close each reference of the reentrant VIs, the more time they were opened for, the more time will take to close them.
As you can see in the attached VI, since I use shift registers, i thought that it could take long time to deallocate all the memory used by the registers, but the problem still remains even if I set the maximum size of them to a very small number.
Any ideas on why it could take so long to close? (by long i mean even 5 minutes)
thanks in advance
(4,096 Views)
here are the vi...
(4,093 Views)
Accepted by topic author loba
Your reentrant2 has an "Open VI ref", with no Close, in a loop with no obvious means of throtling, so I would look to that first.
(4,070 Views)
It is much more helpful to us to attach VIs, not static pictures of VIs.  I'll wait to see the VIs, which (among other things) will (a) tell me the version of LabVIEW you are using, (b) allow me to see the other Case code, and (c) allow me to "cosmetically reorganize" your code so that I can "visually grasp it" more easily.
Bob Schor
(4,041 Views)
hi,
thanks for your reply. I found out that the problem was that the "Open VI reference" block was inside the while loop. I took the block outside the loop and now all the non reentrant VI close immediatly.
(4,040 Views)
