cluster analysis
Hi all,
Does anyone know if LabVIEW has the function of cluster analysis? http://www.statsoft.com/textbook/stathome.html?stcluan.html&1.
Or have some example codes for that?
I have seen through the Mathematics section but I cannot find any subVI that is similar or am I miss some subVI?Smiley Sad
Thanks in advance.
Io
(3,930 Views)
Hi Io,
i don´t read the whole linked article, so can you please explain in more detail what you want?
Mike
(3,900 Views)
Hi!
Cluster analysis actually is an graph analysis skill to select the the grounp of data that leads to the serious bias of teh whole set of data.
It always use in a graph that has a different groups of data and when you draw a line that  match  those data sets, the curve would have a large variance than the actual data has.As a result of that, filtering the data set that have the serious different between the variance of the whole data set is the main theme that cluster analysis would do.
Thanks.
Io
(3,894 Views)
Hi IO HUI,
I did some digging, and it doesn't look this vi is featured in any of our toolkits.
I highly recommend you create a product suggestion to let the developer's know exactly what you would like to see!
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,870 Views)
HI!
Thanks for your reply.
I have submitted the suggestion for that but at this moment, I would still work hard to see what I can do to the similar function for that.Smiley Happy
So,, does anyone have some experience for the similar task?
Thanks in advance,
IO
(3,854 Views)
