cluster into Waveform
Hi
How to convert the waveform(cluster) into waveform(DBL).
I have attached the code,in that i need to aquire a signal and measure the peak to peak value.
(3,720 Views)
Hi vrk,
where's your attachment?
Hint: Don't use the "Preview Post", otherwise attachments are lost...
(3,719 Views)
Thanks GerdW
Sorry i forgot to attach it
(3,715 Views)
Hi vrk,
unbundle your cluster and use the "build waveform" function.
Mike
Message Edited by MikeS81 on 04-23-2008 01:45 PM
(3,709 Views)
Thanks Very much mike
(3,694 Views)
