cluster to data file
I really like clusters, all through the program, right up to the end where I have to take the data out and write it to a delimited text file. The cluster to array conversion VI works great if your cluster has all of the same data type, but that makes the cluster less useful.
I'm designing final test boxes for our product. Hit the test button, get a pile of data, pass or fail the part, then write the data to a text file. I've attached the VI I was using back for an early version with less than half of the data to output than I have now. Also attached is the a control which essentially shows the cluster of clusters that I need to break apart to get to the data.
I suppose I've programmed myself into a corner and I'll just have to slog through it, but any suggestions would be *so* appreciated!
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,995 Views)
I tried to use the xml to string vi, and all of the values are 0. I suppose having a cluster of a cluster of a cluster is just getting to be too much.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,987 Views)
