Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
cluster to easy text report?
HenrikF
Member
12-19-2007
10:56 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How can I display data of type cluster in an easy text report?
Pls. see example attached.
MeantoReport1.vi 11 KB
0
Kudos
Message
1
of 2
(2,538 Views)
Reply
Re: cluster to easy text report?
johnsold
Knight of NI
12-19-2007
11:56 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The Easy Text Report.vi requires a string as input. Use Format into String or other numeric to string functions to create the string you want. You probably do not need the array or cluster.
Lynn
0
Kudos
Message
2
of 2
(2,530 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
