cluster tunnel exit while loop
Using LabVIEW 8.2
Have the attached VI testing cluster operation.
Cluster created in a while loop from enum, numeric control, and enum values.
Cluster sent to tunnel, but doesn't exit.
What simple thing am I missing?
(3,467 Views)
Here's another shot keeping everything in the while loop.
It does work.
Still don't see why the original VI didn't work.
(3,457 Views)
It's the data flow... In your first example, the while loop is never terminated, so no data is coming out of it. You only have the data available at an output tunnel once the while loop terminates.
(3,452 Views)
Alright.
Thanks.
(3,450 Views)
