cluster
Hi! When I've defined an output cluster with 8 elements,
how can I write only 3 values in this cluster, because the other 5 I don't need right now??
(3,492 Views)
Hi
I usually create a constant of this cluster, wire it to a bundle by name node, wire the necessary values and wire the output to the cluster terminal.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,486 Views)
Use the Bundle by Name function in the Cluster subpalette. Wire the cluster value or a corresponding constant to the function input (you can create the constant right-clicking on the cluster terminal and selecting Create->Constant), then select the names of the elements you need.
Finally wire the output to the indicator.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,485 Views)
It would be better to wire the cluster value than a constant cause the unwired entries will take the value of the constant. If your use a local var of your cluster, the unwired entries will keep the same value.
Yann
Yann Falevoz
R&D Engineer, Instrumentation & Software
(3,467 Views)
If there's a while loop it would be better to use a shiftregister if there is data written at several places. This reduces the memory usage as no locals are necessary.
Using LV8.0
(3,464 Views)
