clustering different type of data
Hi All..
I have a problem of clustering 2 kind of different data... my outputs from devices is 1d array and scalar types. And in order to plot graph as loop running i intend to use XY chart vi, in which Buffer chart vi. require cluster of both x and y datas.
When I directly bundle my 2 outputs (1d array and scalar type), output cluster is not accepted by inout of buffer chart vi.
Then i tried to first converting scalar data to 1d array ,and bundle that with other 1d array data but it didnt work  neither..
what can i do?
Message 1 of 9
(3,423 Views)
What exactly is this scalar data??
can you post a sample of data? or a snapshot of your block diagram? or your vi itself??
Message 2 of 9
(3,418 Views)
it s output of Kepco power supply. it s stated as ""double(64-bit real|-15 digit precise)
i attach the file where u can see 2 output as marked in circle..
thanks
Message 3 of 9
(3,410 Views)
do post a snapshot of your block diagram too
Message 4 of 9
(3,399 Views)
sorrz for inconvience.
here it s the vi where there 3 measurement data outout..
Message 5 of 9
(3,390 Views)
Ok, I had a look at your vi.
One question I ask
Do you want to plot data of the array 'measurement 1' against the measured current( Measured Current ??
Am i understanding correct??
Message 6 of 9
(3,357 Views)
One question I ask
Do you want to plot data of the array 'measurement 1' against the measured current( Measured Current on a xy graph ??
Message 7 of 9
(3,357 Views)
Yes..thats correct. I want to plot measurement 1 against current on a xy graph. As u see one of out put is scalar wheres other one is array. Array's first element is changing and the rest is zero after each iteration. So i think to pick up  the time the first element of array ,and convert it to scalar so that i can plot two scalar value using xy graph..
u think it s ok?
Message 8 of 9
(3,346 Views)
That would give you just one point on the XY graph
probably, you will have to accumulate the values that you get in each iteration ( using arrays/ shift register) and plot them on your XY graph
Message 9 of 9
(3,308 Views)
