cmu200 drivers issue
Hi all,
I am a basic programmer using LabVIEW 8,5
I have a project on hand right now. I have to configure the CMU200 in order to
make a call and perform some measurements.
So far, I have installed the following drivers:
- CMU200 Base drivers - rscmu200_lv8_4_50.exe
- CMU200 WCDMA drivers - rscmuk6w_lv8_4_50.exe
My application needs to check the value of the DPDCH channel. The vi-s that i'm using
can only set this quantity and i can't find the one that can read that. Do you think i need
to try to handle directly with the library (try to add this extra vi) or i have to necessary contact the
CMU200 vendor (Rohde & Schwarz)
Another problem i've encountered regards the DL BLER reading in a RMC CS call.
The vi that i have found to performs this returns only integer values of the BLER (eg: 1% ,2%,10%)
resulting not very useful for the application. (the CMU instead gives a decimal digit precision eg: 1,2%)
I would appreciate any suggestion and help!
Thank you.
Vaso Kaculini
(2,819 Views)
Hi Vaso,
I am sorry but I'm not able to help you since you are using a library that has been developed by a third party company (Rohde and Shwarz). You should contact them directly, or you could have a look at their web site where you can find drivers and some examples.
Best Regards,
Serena Monti
Applications Engineering
(2,785 Views)
