cnstruire un dll a partir d'un vi
hi all
I want to know if we can make a dll with vi as the one I sent you are attached
thank you
(2,589 Views)
Yes, you will be able to build a DLL from a VI in LabVIEW, however, you need the professional version to do that ( https://www.ni.com/en/shop/labview/select-edition.html ) or the "application builder"( https://www.ni.com/en-us/shop/product/labview-application-builder-module.html ).
You will find information on LabVIEW help: application builder >> building a shared library.
I suggest that you use a string as the input of the dll and an array of strings as the output of the dll.
You can use the functions "string to path" and "path to string".
Thomas B. | CLAD
National Instruments France
(2,568 Views)
OK THANK YOU FOR YOUR HELP
COORDIALEMENT SKIP
(2,548 Views)
