co-simulation
Please help me
Co simulation multisim labview (3 -phase PWM inverter )
On Multisim the current graph and the voltage garph are correct
on labview I think it is a mistake
The PWM is simulated under labview
(3,657 Views)
I haven't been able to run tests with your files yet, but what exactly is the difference in results that you are seeing in LabVIEW?
Also, have you noted if this occurs with other designs, or is it particular of this one.
(3,590 Views)
Multisim on the results are okay
the results are the shape of current and voltage
by cons are not on labview
(3,569 Views)
Where you  able to test other designs in LabVIEW to see if this is exclusive to this design.
I'm also not sure what  you mean by "by cons are not on labview" could you please clarify what you meant by that.
(3,535 Views)
