code error 20352
I'm trying to resample and smooth a sine wave. I keep receiving the error code 20352 on the error out of "reasampled waveform vi." and no signal on the output, "resampled waveform out".
How do i move on?
(3,182 Views)
Hi shermesh!
This error code relates to having gaps in your waveform data.  How are you acquiring the temperature data? Also, it would be helpful if you could post your VIs.  Thanks!
Kristen H.
(3,148 Views)
