Showing results forΒ
Search instead forΒ
Did you mean:Β
code of light Ac light dimmer
please I need the code with labview of this circit http://www.instructables.com/id/Arduino-controlled-light-dimmer-The-circuit/
(3,361 Views)
I'm afraid nobody on this forum is going to have the code for you on how to control that light dimmer.  I'd suggest contacting that website and see what they have.  If they have at least some other program in another programming language, then it MAY be possible to translate that to something that will run in LabVIEW.
(3,352 Views)
Use a DAQ card with a timer/counter. With that gemerate a TTL PWM siginal that fires a zero-crossing solid state AC relay.
-AK2DM
(3,341 Views)
