Les Hammer wrote:
> If that's not a concern, note that
> your PC's sound card may have low and high frequency roll-off, and
> might not have very good frequency response in general, and might not
> be linear.
Yes this is very important. Audio inputs are usually limited to a
frequency range of 20 Hz to 20 kHz. As long as you only want to read in
audio signals the only other problem might be the accurracy which
despite of 16 bit delta sigma converters is usually not very high. That
is not a problem for audio signals as the absolute accuracy of the DAC
is not important here.
However if you want to read DC or near DC voltages (also temperature
signals for instance) you will measure basically nothing at all, since
the input can't see the DC part of the
signal.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
