color box change with sensor value
how can i use a color box to display a sensor value..? i tried but it's just dark blue to light blue..
e.g if i have a distance sensor the colour box will change gradually from red to green(perhaps and yellow for the middle) for a value from 0 to 255..
(3,353 Views)
you can use an intesity chart
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,346 Views)
what is intesity chart..?
labview has nothing about intesity chart in help..
(3,337 Views)
Accepted by topic author karpa
Try this, just uses some simple interpolation.
(3,334 Views)
This one works too.
Tim
GHSP
(3,331 Views)
although both answers are what i want i liked Darin.K code because is smoother and more easy to edit..
Thanks!
(3,326 Views)
