color image with LabView6
I'm using LabVIEW6i Professional Development System and upgraded to LabVIEW6.0.2. When I open the build in IMAQ example codes, the example can't excute and always search the lib file. I cannot find the example code from LabVBIEW:
National Instruments\LabVIEW\examples\2. Functions\Color
- Color Distance.llb
- ColorLearn Example.vi
- ColorMatching Example.llb
also. It displays an error message about insert the CD. Which CD should I insert?
Can I create color histogram for an image or video with LabVIEW6.0.2 version? Besides, I do not have IMAQ device. Can I use the *.lib of IMAQ in my program? Please help. Thank you.
(2,732 Views)
Those shipping examples are installed with the IMAQ Vision Development Module. Do you have that software installed? If so, try uninstalling it and then reinstalling it. During installation, be sure to select to install support for LabVIEW 6.
If that software is not currently installed, then you will need to install it before those examples will be available. Those examples will not necessarily require that you have an IMAQ device. They can be used with image files as well. Either way, you will still need the Vision Development Module.
If you have not installed the software, try doing so. If you already have it, try uninstalling and reinstalling it.
Please let me know if you have any additional questions on this issue.
Scott R.
Scott Romine
Course Development Engineer
(2,713 Views)
