color matching
 I want to develop the color matching code such that select color ,that should match in the image and it should be indipendent of size,shape angle, if  the color available in the image.
   Please share the suggestion
(4,812 Views)
This is not a place to hire, for free, LabVIEW experts.  If you want to develop this code, and want some help when you "get stuck", post the code you've done so far, tell us (in words, as specifically as you can) what you are trying to accomplish, and we can make suggestions.  Otherwise, do a Google search for "LabVIEW Contract Work" or something similar.
Bob Schor
(4,143 Views)
Accepted by topic author 9964022629
I try to understand Your problem, and write little VI which may be can help You in feature.
Certified LabVIEW Architect (CLA)
(4,137 Views)
 I have a color image which contains varies compoments which are in different shapes and different colors. I want to develop a code such that if I select a color corresponding components should only display and also overlay on the input image. your code which is shared it helped for me. If you have any suggestion please suggest me.
(4,079 Views)
