color pallette in run time menu
is there a way to put color pallete/color selection box in custom run time menu?
Ritesh
Message 1 of 8
(4,162 Views)
You can use a colorbox control to enter colors at run time.
Message 2 of 8
(4,159 Views)
I want it in a run time menu and not a separate control
Is this possible?
Message 3 of 8
(4,138 Views)
I think you would have to create your own containers in order to accomplish this.  I was hoping that ms paint would have an activeX control that could be implemented in order to accomplish this, but I haven't been able to find anything.  So, in short, I think altenbach's suggestion is your best and easiest way to give the user a usable color palette - try putting a color box in a tab control, or something similar.
Julian R.
Message 4 of 8
(4,102 Views)
If you feel adventurous you could try the .net clolur dialogue:
http://msdn.microsoft.com/en-us/library/system.windows.forms.colordialog.aspx
Im afraid I dont have any examples though.
Message 5 of 8
(4,087 Views)
Here's kind of a kludgy way to do it (I haven't tried it, but it should work):
Have a color box on the FP that's hidden.
Trap the 'Menu Selection?' event, and within that event case, unhide the color box and move it under the mouse pointer.
Discard the menu selection.  Trap the 'Mouse down' event on the color box, and re-hide it.
Message 7 of 8
(4,036 Views)
I have done just that before and the results are pretty good.  As long as you remember to hide the color box again after a selection, or user dismisses the selection.  Otherwise you have a one pixel color box on top of what ever part of the control the user right clicked.
Message 8 of 8
(4,033 Views)
