color property
Spent a few hours trying to change the colours on a blinking Boolean button!!! Wished I had read this last bit first, moral in the story somewhere!
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
Message 21 of 25
(1,629 Views)
This was reported to R&D (# 43E7CHXC) for further investigation.
This notification posted for tracking purposes.
Chris C
Message 22 of 25
(1,595 Views)
Pls see the Motor Control VI, It changes its color based on the enumerated control. Also you can import pictures/BMP or .JPG etc from your computer.  but you have to create the control for it.
Message 23 of 25
(1,565 Views)
I would like to know how we can replace the U32 array type by a color boxes array. In the property node help it is said that we can set the color of the front panel object by wiring a hexadecimal number with the form RRGGBB or by wiring the color box constant to the property.
When I change my property to Write and wire a color box it doesn't work. If I create a constant it shows me the U32 type and if a place a color box in the array it makes an error.
Thanks for the info.
Message 24 of 25
(950 Views)
Hi Weepet,
Please see the firat post on page 2.  There is an example that you can work off of.
Che T.
Message 25 of 25
(922 Views)
