color
rwbrook,
Is there any reason why you have two sets of the active plot property nodes? Have you tried passing the color to the Plot.Color property on the property node? I think what's happening is that right now, the waveform chart is using the default colors (plot 1 = blue, plot 2 = red, etc.). I think if you pass the associated color to a Plot.Color property node, it will write the color to the correct plot. Here's a pic of one option. The color array you have generated will work as the color array in this picture.
Robert B
RF Product Support Engineer
Message 11 of 13
(523 Views)
In a parallel discussion it was explained that these are for different graphs. No way to tell from a picture, because the labels are hidden.
Message 12 of 13
(518 Views)
Altenbach,
It works!  Now, I want to clean up my code and I understand using the same property nodes (one for the waveforms and one for the fft overlays), but how do I tie the six boolean on/off switches to one for next loop?  Were you able to run the vi with the sample data?
Ron
Message 13 of 13
(505 Views)
