colour System Control
Dear all,
is there a way to colour a System Boolean Control.
I am using a System Boolean control with "Change when pressed" Mechanical Action. It want it to be Green when True and default when False. But i am unable to color it in the Customization mode.
How can i color it ?
Ritesh
(3,726 Views)
Accepted by topic author LVCoder
Controls from the system palette are color matched to the theme of the OS and cannot be modified.
If you want to use custom colors use a control from one of the other palettes.
(3,724 Views)
No, of course not. The whole point of system controls is that they match the color of all other windows controls and can only be set by the windows Display Properties.
p.s There is no such thing as 'Change When Pressed' mechanical action
(3,722 Views)
Ok, Altenbach.
Thanks for the clarification.
(3,721 Views)
Oops. Sorry. Its "Switch when pressed". :smileyhappy:
(3,718 Views)
