colour change in a 3d graph - spherical
Hi is there a way to change the sloping effect of clour shading in a 3d image, where in this one the values change from a small value of the base axis from right to left they start as light green and go through to black on the far side. is there a way to set it to look at different values, for example is i was using shepical coordiantes is there a way to tell teh graph to set the value change for the difference in radius instead on an angle??
Also on a related note can you cahnge the grid view to be more accurate for a spherical coordiante system as the 3 axis look is only really correct for cartesian coordiantes.
john P.
(3,439 Views)
Hi John,
What version of LabVIEW are you using? Could you post your VI which generated that picture? I will see what I can do for you.
(3,409 Views)
Hii actually think i was being thick, i think the system is already set to do what i wanted, although the shading does seem a bit off, as the lowest values don't appear where expected
(3,397 Views)
In most graphs, the shading is described by the light source in that 3D graph. You might need to see where your light source is in order to have the right orientation of shading in your graph.
Cheers,
(3,395 Views)
ahh then it might not be fixed, here's my VI for you to have a play with.
John P.
(3,393 Views)
Could you save the values that produces that semi-dome as default? In that VI, the values give me a flat surface, it will be helpful.
Thanks.
(3,389 Views)
Hi yeah sorry switch on the front panel from cartesian coordiantes to spherical coordiantes.
sorry should set that as a constant not a control
John P.
(3,383 Views)
