colour image processing
i want to convert an array into a single plane e.g. Red ,green and blue . and again reconstruct  color image  by concatenating these planes. Can anybody help me??
(4,177 Views)
LabVIEW has the "Color to RGB.VI" and the "RGB to Color.VI", located in the conversion and in the Picture functions sub-palettes. Example below.
Marc Dubois
(4,171 Views)
thank you.. Marcbut this is not working.. can you suggest any oyher way for my problem??
(4,117 Views)
You have to be more precise about what is not working. The example I gave is the method to separate an image array into separate color arrays in LabVIEW format. The best way would be to show a simple code example of your problem if you want more help.
Marc Dubois
(4,105 Views)
