comaprison Input
Hi
Please does anyone has an idea to make a comparison between a signal acquired by the NI 9225 module and another signal generated by Labview
I tried to make an example but it gives me no result.
Also you can give me an idea how I can vary the amplitude of the sinusoidal signal in Labview FPGA?
I am a beginner in Labview and I tried to read documents on the Labview programming
(3,441 Views)
There are examples that comes with your LabVIEW. I am sure there will also be a standard signal generator example too. Have you tried them?
(3,436 Views)
Thank you for your attention
In NI examples there is not an example or a project that contains a comparison between a signal acquired and generated another FPGA
Will you help me send me an example or give me an idea.
Please if you can give me your thoughts and opinions in this attached code
The purpose is to regulate the input voltage acquired by the 9225 module comparing it with a reference voltage which is in FPGA
The problem is that it has not acquired the voltage and reference voltage amplitude does not vary
Attached so to the principle of the project
(3,415 Views)
There's no such attachment, buddy 🙂
Try again.
Regards
Mondoni
(3,408 Views)
(3,402 Views)
