comare boolean from excel sheet with constant boolean
Hello everyone,
I need to compare data from excel sheet with 1 or 0 value in vi(data is tored in first column one below the other)? The data in excel sheet is in 1 or 0 form only. so i need to compare the change from 0 to 1 or 1 to 0.
I just want to get the output as an indicator (red colour signal) from that comparison?
please help me with this.
thank you.
(3,712 Views)
Hi ajita,
you may start with one of those:
There are other ways to reach your goal, it's just a kickstarter...
(3,707 Views)
hi thank you for your reply.
i cant see your image file. Will u send it back? try to send it in zipped format.
thank you.
(3,694 Views)
Can you see this one?  This is actually a snippet.  You can drag the image file onto your block diagram and code will automagically appear (2009 and later).
Personally, I'm a fan of the first option here.
(3,691 Views)
thank u i will check and then  tell you.
(3,682 Views)
