combine 2 different methods of measurement
I have to combine 2 Programs that use different methods of measurement :
  -the first one takes a measurement every 10 milliseconds
  -the second one gives every 1 second a table of a 100 measurement (it's measuring every 10milliseconds in an Oscilloscope and sends in the end all the  100 measurements together )
i want to make a table that combines both measurements , so it would have 2 columns : 1 for the first program and 1 for the second one
(2,163 Views)
Accepted by topic author achouch
Hi achouch,
Then you need to do that!
What is your question?
What is your problem?
Where are you stuck?
Why don't you attach your VI?
I would:
- collect measurement results in two arrays, one for each signal
- read both arrays once per second and create a table from the data
(2,145 Views)
thank you for replying even if I didn't make a clear post, it was too complicated  to explain for me and my VI is tooo big and messy so I tried to make a little one that resumes everything but I couldn't
(2,116 Views)
