combine 4 stops for 4 case structure
okay okay Thank you!!!
@Mayur_VIenthusiast wrote:
Hey
Dont worry. Everyone has been a beginner sometime or the other. You just have to have to interest to learn new things. I'm posting a link here. you can learn how to make a subVI from there. Its not complicated, just like creating functions in C programming. You have very good instruction manuals in the NI site. all see that.
http://www.ni.com/white-paper/7593/en/
Message 11 of 13
(541 Views)
@AmeHyesung wrote:
Hi~Apok!!
I just remove the stop button for each case structure. It seems can still working well~
Is that ok?
it will work...but your program will still run, waiting for you to press the stop control. instead, if you wire as example: VI will exit once all cases exit or again, you press stop control using AND compound.
Message 12 of 13
(520 Views)
OKAY THANK YOU !!!
you are so nice!!!
Message 13 of 13
(509 Views)
