Hi, the following is more a discussion then a question, I found two ways to solve my problem, but perhaps there is better way to do it.
Problem: For a bus compatible PID-Control-System (MLC9000 from West Instruments) I have to combine to integer numbers to a new hex value. "Instance" has a value from 0 to 7 and "Parameter Nr." has a value from 0 to 31. In binary form "Instance" reaches from 000 up to 111 and "Par.Nr." reaches from 00000 up to 11111, the target is to combine them in a way that in the binary array "Par.Nr." is on index 0 to 4 and "Instance" is on index 5 to 7. The Result should be: 0 + 25 = 10011000 = 25 = 19h and 1 + 25 = 10011100 = 57 = 39h
Waldemar thank you for your ideas! I added them to my code (see the attachment, LabView Vers. 7.1), I like best the solution to multiply by 32 and than add them to the second integer.
