combining 1-D arrays to save in excel format
I have different 1-D arrays which I want to store in excel. All arrays in a single MS excel file.
How do I do that?
(3,064 Views)
Hi Shan21,
are your arrays from different type? If you need a "real" Excel file, then you have to use ActiveX functions. To write two different array (different type) use two invoke node (value) to write the different types.
If you only need a Spreadsheet file, then the easiest way is to convert both arrays to string and write all at ones.
Hope it helps.
Mike
(3,056 Views)
If I convert it to a spreadsheet, can we manipulate the numbers inside the spreadsheet cause now they are strings?
(3,045 Views)
Hi Shan21,
yes, you can change what you want in your file. Do you need to read the values later?
Mike
(3,038 Views)
Yes I do need to read the values later and make an XY plot for comparsion for the values.
(3,035 Views)
Hi Shan21,
it shouldn't be a problem. Do you have different types? Can you show an image of what you make?
Mike
(3,033 Views)
