combining c# or java in labview block diagram
hello all!
i want to insert piece of code written in c# or java into the block diagram.
is it possible?
it will look like other blocks with input and output?
where can i learn about this ?
thanks.
(3,545 Views)
Hi hookso,
you may use the formula node to include code with C-syntax...
(3,540 Views)
Additionally, if the functionality of the formula node isn't enough for you, you can always make a .dll, which you can then call in LV using the Call Library Function Node. First station for information would be the LV-Help.
btw. nice avatar. Altenbach would like it...
Remember Cunningham's Law
(3,533 Views)
Accepted by topic author hookso
Well, said. In fact: http://zone.ni.com/reference/en-XX/help/371361G-01/lvexcodeconcepts/using_ext_code_lv/
Also: https://forums.ni.com/t5/Developer-Center-Resources/Calling-External-Code-From-LabVIEW/ta-p/3522282
(3,520 Views)
