combining vi.
i need to combine project vi. with basic serial write and read vi so then the read data will be my input
i want to make it likes this..first,as u can see in my project vi..i've a 5 element which is motor current, motor temp and etc..i want to assign each one of them as 8bit hex for example motor current = 0000FFFF, motor temp = 000044FF and so on..so if i received hex 0000FFFF, the 8bit hex after that will be my motor current value and be save in my table under motor current then if i received 000044FF,the 8bit hex after that will be my motor temp value and save to table too and so on for other element..anyone can help me?
(2,616 Views)
(2,586 Views)
