combo box latest value
How is it possble to show the latest value ( last entered value) as default value in a combo box ??
For example, I enter 1, 2 ,3 and 4 and the close the VI. Next time when i open it value 4 should be seen as defult in combox . Any ideas pleas?
Nghtcwrlr
(2,515 Views)
You need to search the forums for posts on how to save control values between runs of VI's.  Typically, you would save the value of a control to a file such as a config.ini type of file, then read that file on the start of your VI and set the control values accordingly using local variables or value property nodes.
(2,500 Views)
