combo box update
How do you get the value of a combo box as the operator scrolls thru the list with the arrow keys?  Combo box updates once the operator presses enter but I would like the value in real-time.
Paul
I have attached a very small example I am working with.  I need it to work with the event structure in order for it to be implemented into my current software.
(3,697 Views)
Hi Novatronics,
You could try replacing it with a Dialog Ring?
See attached.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,685 Views)
I tried your example Charlie but it did not seem to update until either a mouse click or the enter key is pressed.  My goal is for the event to fire every time the operator presses the arrow up or down.  I would like to know which item the operator is currently looking at as they scroll thro the list.
(3,675 Views)
It is easily done if you can convert to a text ring.
Message Edited by tuned99 on 10-04-2005 08:55 AM
(3,663 Views)
