combo box
@RavensFan wrote:
IOne possible bad aspect is that 15 tabs is a lot of tabs to put on a tab control.  I would then consider making that tab control an indicator and hide the tabs.  Use the ring has a control wired to the terminal of the tab control indicator.  Now when you change the ring, it will bring up a different page of the tab control.
I've used that on several occasions and it's a slim solution. 1 Enum with the tab names and a value change event to change the tab (tab names hidden). Easy to implement and keeps UI clutter to a minimum.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 11
(1,152 Views)
