comm with psu using pda
Hi all,
I just wrote a simple read write program on my pc to communicate with the TTi programmable psu which worked without a problem. I then proceeded to download this program to my pda and hooked up with the psu but the program does not work.
Is there some major difference between the pc and the pda communicating abilities that i am not aware of. Is the software vxHPC compatible with labview?
If i have not provided enough info with regards to my question please let me know and as always any help on this problem will be greatly appreciated.
Cheers,
Lil
(2,863 Views)
Maybe you used VISA. VISA is not available on PDA. For serial comms, you need to use serial compatibility vi's.
There are examples specific to PDA you can try.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,858 Views)
