comma delimited number to array
You need to post a VI that actually has values. Go to the Edit Menu and select 'Make Current Values Default'. Save the VI. Attach it.
In any case, the delimiter control is NOT set for \ Codes Display. That is the important one.
I've tried with a ,\00 delimiter and it worked for me.
Message 11 of 14
(1,215 Views)
Thanks!
The delimiter was constant and I then changed ti to a control. After setting the control for Codes Display as well. It works!
Message 12 of 14
(1,209 Views)
You could have set the diagram constant to \-display instead. 😄
(If you leave it as control (not recommended!), you need to make sure to make current value the default and re-save, else the value is lost once you close LabVIEW.)
Message 13 of 14
(1,202 Views)
I have changed it to a constant again.
I learned a new trick from Dennis (Make Current Value as Defalut). The stored values will be still there after reopen the VI. It is helpful for my programs!
Thank you two!
Message 14 of 14
(1,197 Views)
