command line with flash magic
Hi :
I want to control on flash magic application using command line with Labview, I look into this application and I see that I can send through command line all I need
Please read what they said aboue using command lines
Before you can run FM.EXE on the command line you must set up your PATH environment
variable to point to the folder FM.EXE is stored in. This is done automatically during
installation, however you must restart your machine before the change to the PATH variable
is recognized when using Windows 95/98/ME. You must restart your machine or log out
then back in again before the change to the PATH variable is recognized when using
Windows NT/2000/XP.
Commands are passed to FM.EXE in the form or either directives or a Command File
containing directives.
The command line will have the following syntax:
FM [directives]
For example the following command line:
Description:  Specifies the PC Serial (COM) communicating
Type:      Configuration
Syntax:    COM(port, baudrate)
      Where:
      port    The COM Port t
      baudrate :
          2400
          4800
          9600
          19200
          38400
          57600
Output:    Connected
      Or: Connection failed: reason
      Where:
      reason   The reason the
Default:    COM 1, baudrate of 19200 (COM(1, 19200))
Examples:         COM(1H, 9600)
                         COM(1, 0x2580)
                         COM(0x01, 2580H)
I try to used this command line with Labview but I always get error attach see file please
What I am doing wrong ?????
Message 1 of 12
(9,361 Views)
did you check the PATH variable ? Does it contain the FM Path?
Try "cmd /c FM.exe" with wait for completion TRUE and minimized FALSE.
What is the result in cmd window?
Balze
P.S.: Maybe the wait for completion and minimized are called different, I've got an german LV
Message 2 of 12
(9,330 Views)
AAARGH,
ignore the above mentioned !!!
Your working directory should not be an *.EXE file !  Smiley Wink
Balze
Message 3 of 12
(9,328 Views)
I've had a strange problem with the Flash Magic command line tool via system exec.vi, when using it to load a .hex file from a library which had brackets in its name it didn't work, once I removed the brackets - all was good. When I use the FM GUI it works in both cases, so does other executables.
I tried to look for a note or comment on that issue but found none, I would appreciate any help on the matter.
Amir
Message 4 of 12
(8,480 Views)
Hi AmirBerN-trig,
Based upon the information that I found on the Windows command line syntax, the square brackets, aka [ and ], indicates to the command line that the text inside is optional. Maybe that is why the file opened properly when you removed the brackets. Hope this helps!
Sam Burhans
Senior Product Manager
Message 5 of 12
(8,440 Views)
Hi CofeeBreak,
Thank you for your comment, but I was able to find the problem (didn't solve it yet): In the FM command line interface, calling a HEX file located in a folder with brackets in its name, such as "C:\hello_World(V1)\LabVIEW.hex" will not be recognized by the FM.exe, whereas "C:\hello_World_V1\LabVIEW.hex" will work just fine. In the Flash Magic GUI and Command Line Manual section on hex files there is no mention of that, my solution at the moment is to remove the brackets from folder names.
Amir
Message 6 of 12
(8,411 Views)
Could you able to flash using Labview?
Message 7 of 12
(7,292 Views)
You want to know if i've been able to flash using FM.exe and LabVIEW?
YES!
(I answered your question! Please give a kudo.)
Message 8 of 12
(7,285 Views)
I'm interested to know what are the commands have been used as i dont get enough information for erasing & programming.
If possible can you send me the details about it?
If you can able to share the VI it would be great 🙂
Message 9 of 12
(7,278 Views)
As you may have noticed, this topic is more than 3 years old.
I did not use FM.exe since then.
All you need (from LabVIEW perspective) is shown in the jpg in the first post.
LaBVIEW just calls the FM.exe (via cmd /c) with appropiate command line options.
The Command line options you have to use depend on your setup and you have to figure out on your own.
There are a lot of forum entries regarding fm.exe command line options and the usage.
Try to use google to find these threads.
(For example: http://forum.flashmagictool.com/index.php?topic=3066.0 )
Message 10 of 12
(7,262 Views)
