communicate between 2 parallel running while loops
is this possible? my aquistion is in one loop, and i have anothe loop which is collecting the samples the writing to file. i cant put the collecter in the aquistion loop as its set up to stop on triggers, thus reseting the data stored in the collector. so can i tunnel data out of the first loop into the 2nd one?
thanks
(3,507 Views)
Search for producer/consumer design patterns. Also look at queues.
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
(3,503 Views)
great n thanks for that 🙂
(3,499 Views)
