communicateur de crash application
Hello
I have got with an access violation error which forces my exe build by LABWINDOWS/CVI to crash
I have a doubt in two things :
1 - i calling a DLL built by LABVIEW and can possible cause the crash.
2- My program communication to CAN bus by XNET devices (i use NI CAN library) i installed NI-XNET Compatibility Library for NI-CAN
Looking forward to your help
thanks
(3,140 Views)
Hi Araibia_IngDev,
Has your executable ever worked in the past? How often does the crash occur when you try to run your .exe? Do you know at what point in your code your executable crashes and if it happens at the same point or different points in your program?
Robert Leonard
Applications Engineering
(3,105 Views)
Just make sure that your .dll is not open in LabVIEW at the same time as in your executable.
Close LabVIEW and open your application.
Benoit
(3,100 Views)
