communication between parrallel loops
implement ethernet connections in each loop
next step: use a server on the other side of the internet Smiley Very HappySmiley Very Happy just because 127.0.0.1 is much to easy Smiley Tongue
Message Edited by Henrik Volkers on 01-27-2006 01:47 PM
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 23
(3,153 Views)
Great one Henrik..
One could also program two robots - one to write the data ona piece of paper, which is put into a cryptex (refer to Dan Brown's Da Vinci Code). This cryptex is transfered to the other robot (due to the fact that the data is in a cryptes you have it absolutely secure), which opens the cryptex to read the data again. To transfer the code of the cryptex, we could use the internet-method... :D:D:D:D:D
Ok - let's get serious again...
Message Edited by becktho on 01-27-2006 01:51 PM
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 12 of 23
(3,150 Views)
How about VISA write and read with a loopback connector on the serial port.
Message 13 of 23
(3,139 Views)
its hard to find PC nowadays with two rs232 ports,  (mine has only one) BUT using the DTR/RTS and the parallel port pins allow communication.... or
More hardware would be a USB hub with two USB/Rs232 converter and null modem cable. But you can hide all that in one USB-Loopback-box with a single connectorSmiley Very HappySmiley Very Happy
Henrik
LV since v3.1
Message 14 of 23
(3,145 Views)
I liked that becktho...Smiley Very HappySmiley Very Happy My unofficial ***** rating for this.
nudalakasim
Message Edited by Nudala on 01-27-2006 07:36 AM
Message Edited by Nudala on 01-27-2006 07:38 AM
Message 15 of 23
(3,145 Views)
Message 16 of 23
(3,138 Views)
I really don't understand why you're all going these complicated ways. I think the simplest thing is just to let the user have 2 controls and just let them enter the data for each loop. This is even more versatile, because it can easily be used to have different data in each loop. Also, you won't need to hide the indicator because there will be 2 controls.
Debating with self...
OK, decided to be safe, so here it is - Smiley Very Happy
___________________
Try to take over the world!
Message 17 of 23
(3,133 Views)
Has anyone considered telepathy?
AKA "this damn program is going to do what I want it to do, not what I'm telling it to do!"
Message 18 of 23
(3,116 Views)
WoW..This has become a popular thread....Popular for the 'pun' ofcourseSmiley Wink
nudalAKasiM
Message 19 of 23
(3,104 Views)
Alternatively, you could use RFC1149 for the data transport. A working implementation is described HERE. 😄
Message 20 of 23
(3,091 Views)
